Ring Gap 13 to 1 piston
These sound a little tighter than I am used to. I don't like any more blow-by than absolutely necessary.......but on the other hand I have seen what DS motors do if the ring gap is insufficient. It isn't pretty and it was expensive[img]i/expressions/face-icon-small-wink.gif[/img]
The fall back advice I would give is to ask your piston manufacturer what they recommend for that piston and ring kit. They will ask if it is for a NOS application or not. On my 730 I ran a .022 ring gap. My 800 is setup for NOS so I have the ring gap at .028..........they are both 105.5mm bore[img]i/expressions/face-icon-small-wink.gif[/img]
The reason for asking your piston manufacturer is, #1 liability...........none of us want to tell you the wrong number and have it fail. Reason #2 is only your piston manufacturer will know the concentration of silicone in your forged piston. The effects the expansion percentage which will effect your ring gap also.
More Gap Specs
The effects the expansion percentage which will effect your ring gap also. !!!!!!!!!!!!!!
Rings float.
Rings float.
Originally posted by: OMR
More Gap Specs
Rings float.
More Gap Specs
Rings float.
exmotocrosser
Sep 13, 2019 06:12 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
