Explorer 400 pipe on Scrammy 400
Old Dec 6, 2006 | 09:44 AM
450trailrider's Avatar
Default Explorer 400 pipe on Scrammy 400
Will a 02 400 Explorer pipe and silencer fit on a 02 400 Scrambler ???
Old Dec 9, 2006 | 12:11 AM
RDZ350's Avatar
Not sure.You might visit hpd-inc or hotseatperformance website and get their # and give them a call.
Old Dec 9, 2006 | 01:00 AM
handycap's Avatar
With a little fitting possible, it will fit.
I put a '98 400 Explorer Aaen Midrange pipe on my '03 400 TrailBlazer. Just had to add a little heat wrap around pipe near rear fender because it touched plastic. Now I have a Chrome HPD top end pipe on the '03 that was for a '99 Sport 400.............They must be all the same!
handycap
I want a 700 Prairie Kawie
Old Dec 9, 2006 | 12:48 PM
I am confused. I called Aaen and asked if it would fit since it has a different part #. They let me talk to some shop manager and he said that any of the 400's pipes should interchange.
I called Ritter cycle and he said that they were routed differently and would not interchange.
I just do not know......
Old Dec 10, 2006 | 08:48 AM
RDZ350's Avatar
Looks like if one pipe would work on both then they would just sell one pipe??????
Old Dec 10, 2006 | 09:49 AM
That is what I thought. Why would they complicate their system with two pipes when just one would work.
Old Dec 10, 2006 | 12:09 PM
LSkrabut's Avatar
An Explorer pipe is created with a different power band in mind than a Scrambler pipe is, so hence different part numbers.
R U sure U want to detune your Scrambler with a Explorer pipe even if they did fit? I am pretty sure there is a frame difference involved here also, but not much of one. I would gather they would fit with some slight tweaking, cause I have read where ppl used a Scrambler pipe to update there Explorers in the past.
If U did this anyway U would have to rejet accordlingly and do some clutch work de-tuning the Scrambler after an Explorer pipe was placed on it.
Why R U asking this anyway, degrade the pipe power band on a Scrambler if I may ask?
Old Dec 10, 2006 | 02:29 PM
This is an Aaen pipe and silencer kit. The guy also has the clutch kit with it.
I "thought" that it would be a 10Hp improvement.
Old Dec 10, 2006 | 03:15 PM
After some more internet research I decided that it will not fit without some major mods. For one the silencer on the Explorer bolts on with one mount on top, the scrambler bolts on with two- one on each end of the silencer. The headpipe looks to be coming out at a different angle than on the scrambler.
Old Dec 10, 2006 | 03:17 PM
RickRitter's Avatar
I remember discussing this on the phone . The question is will an Aaen Explorer pipe fit a scrambler .
IF you had the Explorer exhaust manifold , factory U-bend then it MIGHT . (Notice use of words IF & MIGHT) The problem that may present itself is coming around the frame up front , I am not sure if the it would clear. IF it did fit the power would be increased , the Aaen expansion chamber would make more power than the original , the tuning specs between an Aaen Scrambler torker pipe and an Aaen Explorer pipe are I am sure very similar , in a nutshell - IF it fit , it would run and tune just fine .
Using the factory S-bend and manifold from a Scrambler and trying to hook a Aaen Explorer pipe to it I can assure you WILL NOT work .
Just trying to help ~ Rick Ritter
PS - Handycap has done this it looks like - Handycap - did you use a Explorer U-bend and manifold ?
