1993 350L Dies when put into reverse HELP
Old Dec 10, 2006 | 05:04 PM
SherpaT350's Avatar
Default 1993 350L Dies when put into reverse HELP
When this atv is shifted into reverse it wants to die . It will go forward fine and does not die . Then of course if you try to rev it up when putting it into reverse it grinds . Any ideas as to what the problem is ?
Thanks so Much,
D.
Old Dec 10, 2006 | 05:27 PM
scrammersam's Avatar
have you been useing the override button?
Old Dec 10, 2006 | 06:53 PM
SherpaT350's Avatar
No, I haven't been using the overide button . Should I try pushing it in when I put it into reverse and see if it keeps it from dieing ?
Otherwise no, I haven't been using it.
Thanks,
D.
Old Dec 10, 2006 | 09:42 PM
ftwflh's Avatar
Find the black wire coming off the rev limiter and unhook it.Your problem will be solved
cornbread2's Avatar
Your problem is the reverse rev limiter black box. You can unhook it or replace it.
It is located under the headlight. It is a small black box next to the CDI box.
Old Dec 10, 2006 | 09:59 PM
SherpaT350's Avatar
Is this a common problem with the older polaris atv's ?
Thanks for the info. , I will keep you guys updated.
Thanks again,
D.
Old Dec 10, 2006 | 10:34 PM
mine was doing it randomly in forward and i found if i pressed override it would work. so then i unhooked a wire to fix it. its happend to a few machines
pgamboa
Dec 24, 2023 11:52 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
