Large clunking noise
Old Dec 11, 2006 | 12:41 AM
aawhite's Avatar
Default Large clunking noise
what seems to be the problem is a large clunking noise is coming from the rear or center of the bike, hard to tell. So what I was thinking, it might be is the drive shaft b/c even when I turn the bike off and push it while its in neutral it will either lock up or make a clunking noise. Is it possible that the drive shaft could have caused the belt to snap off like it did? Do you think it could be something else? and is this a big job if it is the drive shaft $$$?
00 KVF (PRAIRIE 400 4X4)
Old Dec 11, 2006 | 06:05 PM
FASTFATBOY's Avatar
Have you checked the joints for slack?? It could be your universal is worn out and making the sound. Also I would pull the belt over off and check both front and rear drive pullies for belt fragments. I've gone through a few belts and thought I had all of the pieces of the old belt out but later hear an awful noise and have a small piece or two of belt left inside the housing. Also if the belt shredded then some cord from the belt could be what's trying to lock it up. I don't know if any of this is your problem but it's just a thought.
Old Dec 11, 2006 | 06:57 PM
hammerman's Avatar
Check your swing arm bearings.
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
