05 sp 800 mudzillas tires
Old Dec 13, 2006 | 09:59 PM
Mayorstt's Avatar
Default 05 sp 800 tires
i have a 05 sp 800 and want to know if any one is running a mudzilla 28x08x12 with out a spacer on the front? i am thinking about a 2in lift ,if it will help not having a spacer!!!! any help you can give will appreciated
Old Dec 13, 2006 | 11:34 PM
SPORTSMAN70003's Avatar
Default 05 sp 800 mudzillas tires
With 8's in the front you should be ok. Any wider and you will need spacers.
Old Dec 15, 2006 | 08:49 PM
dano5o's Avatar
what size do u have in the front
Old Dec 15, 2006 | 08:52 PM
I'm running 10's.
Old Dec 15, 2006 | 08:56 PM
dano5o's Avatar
i been told but not from a reliable source that the 8" zilla would not fit on a factory rim with out a spacer
Old Dec 15, 2006 | 09:02 PM
Could be true. Most of the time you can run a 9 on the front without a spacers but it has alot to do with which tire you run. If you look you are running an 8 up front right know so I think you would be ok with the 8 Zillas.
Old Dec 15, 2006 | 09:06 PM
dano5o's Avatar
thanks one more ? any problems out of your lift kit?
Old Dec 15, 2006 | 09:08 PM
Nope not a problem.
Old Dec 15, 2006 | 09:11 PM
dano5o's Avatar
thanks one more ? for real how do you add to the bottom of the page of what u ride
Old Dec 15, 2006 | 09:14 PM
In your profile under signature.
