replacement handlebars
Old Dec 14, 2006 | 01:24 AM
badadatude's Avatar
Default replacement handlebars
I was wondering if anyone would know of other handlebars that would fit an 06 Bf750 that have a straighter bend, and still be able to mount everything back on (plastic and stuff)
[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 15, 2006 | 03:12 AM
bfb750BF's Avatar
You are Not going to find anything that is a Bolt-up for your instrument/pod/plastic w/a aftermarket Handlebar. It can be done But you will need to make it fit by making your own mounting brackets & yes, it can be done & it will give a clean look to it.
1st you need to decide on the Handlebar, many choices out there.
Also depends on what model you need it for, the i model requires a different handlebar than the SRA, at least that is what I have seen posted before.
After months of researching this Subject, I decided on the Pro-Taper Fatbar CR High Bend, 2" Rox Riser/Spider Hand grips for the BF750.
Rockymountainatv carries a great selection of Fat Bars, you need to go to Roxspeedfx for the Rox riser (s).
I now have the Pro-Tapers mounted & am in the process of re-mounting the instrument pod/plastic right where it was on the Stock Handlebar location.
Old Dec 17, 2006 | 11:59 PM
badadatude's Avatar
Thanks for the info bfb. this was the much needed info and links that i was looking for. btw i see Roxspeed even has the dash panel mount to remount the insrument pod.
hmmmm gonna have to see what my visa says i can spend now, LOL[img]i/expressions/face-icon-small-happy.gif[/img]
Old Dec 25, 2006 | 12:27 PM
bfb750BF's Avatar
I have the Roxspeed dash plate but I may not use it. It looks like by using the Dash Plate I might not be able to reuse the plastic pod cover.
I know the stock pod mount will work on any after-market handlebar as I have seen others who have made it work on these Forums.
KOD website has detailed PICs w/instuctions to re-install the stock POD mount/plastic, check it out.
Old Dec 27, 2006 | 04:48 PM
Oooby's Avatar
Mike Penland Sells a bar mount and Dash panel also. I'm getting it and Using the tag 1007 bars. That is what Ken Robey had on his prarie at Sparta last year and felt nice
Old Dec 27, 2006 | 09:06 PM
bfb750BF's Avatar
I have the Mike Penland Dash mount plate but I don't believe it works with the Stock Plastic Pod Cover.
toonces
Aug 5, 2015 05:55 PM
toonces
Jul 28, 2015 01:58 PM
jayking232003
Jul 23, 2015 05:48 PM
trouttracker
Jul 20, 2015 11:54 AM
jettman
Jul 6, 2015 12:16 PM
