oil change
Old Dec 17, 2006 | 12:11 AM
Bigpappa's Avatar
Default oil change
I was wanting to do my first oil change on 500efi but can't locate loctite 565. Local dealer said to use Yamabond 4. What do you think?
Old Dec 17, 2006 | 12:14 AM
BassBlaster's Avatar
Default oil change
What would you be putting Loctite on, the oil plug?
Old Dec 17, 2006 | 12:19 AM
Bigpappa's Avatar
Default oil change
it is a elbow fitting that goes into oil tank that has a screen that is supposed to be cleaned then replaced with loctite 565 thread sealant
Old Dec 17, 2006 | 12:28 AM
Default oil change
Okay I know what you are talking about. I never took mine out because it is so tight I thought I was going to break it when I tried. I don't know how important it is to clean that screen out. I suppose I should get mine cleaned, huh. I wouldn't think you would have to clean that with every change though.
Old Dec 17, 2006 | 12:32 AM
Bigpappa's Avatar
Default oil change
Thanks, I've decided it might be more trouble than it's worth. I've been reading a lot at different pages and a lot of people have broken theirs trying to get them out and several people with many miles have never even attempted to remove, they just drained oil and changed filter...Thanks for the quick response
Old Dec 17, 2006 | 12:35 AM
Default oil change
No problem. I didn't know others had broken theres but I tried to get mine out and felt like I was definately going to break it so I just let it be. I've had my Scrambler for over a year now and been through several oil changes and no problems yet. Good luck if you do decide to try and take it off.
Old Dec 17, 2006 | 11:17 PM
NVMYZ28's Avatar
Default oil change
For what its worth, on my scramblers first and second oil changes - there wasnt a spec of anything on that oil tank screen. I doubt I will ever pull it again.
Ill just keep on top of regular oil and filter changes (I dont want to risk cracking the oil tank by removing that fitting). I suspect if anything of notable size gets stuck on that screen - I have bigger issues to worry about [img]i/expressions/face-icon-small-wink.gif[/img]
Old Dec 18, 2006 | 09:45 PM
sheepdogMSP8117's Avatar
Default oil change
A couple wraps of Teflon tape works well.
ultangler
Nov 30, 2024 01:35 AM
ReconBayou
Oct 31, 2022 05:37 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Gwolf228
Feb 18, 2017 01:36 AM
Jackg17
Sep 26, 2015 09:30 PM
