06 450ER shifting into 2nd
Old Dec 17, 2006 | 06:39 PM
Rise400ex's Avatar
Default 06 450ER shifting into 2nd
Hey guys, I have a 06 450ER that shifts hard into secound gear. It's not smooth and sometime I miss secound and it pops into neutral. It happens more after it is warmed up after riding for awhile. I have tried running Red Line trans oil but that did not seem to help very much. I also have made sure that the clutch is adjusted right. Everything seems ok. I'm thinking it maybe something in the trans that just needs to break-in. I do change the trans oil often and the engine oil. Does anyone else notice this problem with there 450R?
Old Dec 18, 2006 | 02:46 AM
chenoweth122's Avatar
i bought a new 06 as well, i had a problem with my transmission when i first strarted to brake it in as well, mine would not shift in to 3rd, i mean you could pull up hard as you can and it would not shift, i called honda and they said that there was probably a bur on the gear, so i kept riding it and it fixed itself. they have a little warrenty on them, i would get at least 5 good hour or better rides on it, if it is still doing it, take it in.
good luck
Old Dec 18, 2006 | 10:18 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
On mine, it is easy to miss 2nd and end up in neutral. It doesn't "pop our of gear", it just doesn't get to 2nd unless I do the shift very deliberately. I posted this once and several riders said theirs were the same. I think it is just the nature of the beast.
In any case, if this is a new machine that is on warranty, ride it a while and both you and the quad may get better. If it persists after that, it may be something covered by warranty.
Old Dec 18, 2006 | 08:44 PM
Rise400ex's Avatar
That is exactly what my 450ER is doing. I feel better knowing that I'm not alone on this problem. I to have to think and be careful when shifting to 2nd. Has anyone done anything to help this issue or has anyone noticed it getting better over time?
Old Dec 19, 2006 | 10:32 AM
Red Rider
I just shift a little harder, and it's not really a problem any more. If it happens, it can really be a killer in a drag race!
Old Dec 19, 2006 | 12:51 PM
bombrider04's Avatar
Liek reconranger said I have had troubles in the past but you just need to make sure that you shift all the way up and you won't have a problem shifting into nuetral.
Old Dec 19, 2006 | 08:32 PM
exrider91's Avatar
that happens on my 300 ex its not a trans problem like bombridero4 just shift all the way up
95wolv
Sep 27, 2024 12:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
patrick.oc123
Sep 16, 2015 03:45 AM
BigCam
Sep 16, 2015 01:53 AM
patrick.oc123
Sep 15, 2015 02:45 PM
