90cc ATV Jet Borring
Old Dec 18, 2006 | 11:14 AM
atv90jetted's Avatar
Default 90cc ATV Jet Borring
hey i have a little 90 cc and i bored out the main jet. i went to run it and in order to, i had to remove the airducting and put mesh over the end of the carburator for a filter, i tried a 1 foot toob straight up and curved for a air scoop, but once i run it over 2/4 throttle, it dies out, what can i do for a air breather and what should the recommended oil injection be??
Old Dec 18, 2006 | 11:27 AM
hoytultratec's Avatar
what kind of machine is it? and its a 2 stroke?
Old Dec 18, 2006 | 11:34 AM
its a early manco 90cc 2 stroke
Old Dec 18, 2006 | 11:57 AM
first of allyou better put a filter on it,be right on the carb or what you rigged up, you shouldnt of drilled the jet out without taking a plug reading to make sure it was running lean, i think your whole problem might be the jetting, seems like you might have opened it up to big. dont run it with the mesh over the carb thats not a filter.
Old Dec 18, 2006 | 12:20 PM
how can i tell if the mixture now is to lean, like it will run fine wide open, but i dont know how to make sure im not gonna toast the block
Old Dec 18, 2006 | 12:47 PM
check the plug, black is rich, grayish white is lean. your looking for brownish color.
Old Dec 18, 2006 | 12:54 PM
ok, thanks, what would u suggest for a air breather?
Old Dec 18, 2006 | 01:29 PM
is there room to put a unifilter right on the carb, if so i would do that but your gonna have to play with jetting so you dont run lean and smoke the piston.if you measure the the outside of the carb where u put the filter, you can go to unifilter website and find a universal filter to fit. theres all sizes on there u should be able to find some thing to fit.
did you check the compression on it? i would do it before u spend money on other things.
Old Dec 18, 2006 | 02:49 PM
how would i go about checking that?
Old Dec 18, 2006 | 02:59 PM
compression tester, you screw it into spark plug hole it has a guage on it im not sure what the compression should be on that, do you know any mechanics that might have access to one? i would definatly check the compressin before you start doing all these things to it this.
