How to remove ignition switch?
Old Dec 19, 2006 | 09:01 AM
oldfourtrax's Avatar
Default How to remove ignition switch?
Greetings. New to the board, I got referred here by posting this question somewhere else.
I recently bought a 1995 Fourtrax. It came with one key, which I managed to lose the first time I took it to the woods. The quote from the dealer, who is half an hour away, was ridiculous. I called the guy who did the locks on my house and he said he could do it for much cheaper, but that I had to pull the ignition switch and bring it to him (if he had to come out to my house and pull it, would be almost as expensive as dealer).
So, I looked in the manual and it shows all the wiring, but not how to get the switch out. If anyone could help it would be much appreciated. Many thanks.
Old Dec 19, 2006 | 09:38 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
Usually the swtich just has two tabs on the sides that you press and it should pop right out. You should be able to trace the wiring down to some place where you can just disconnect it.
Old Dec 22, 2006 | 09:38 PM
SFA's Avatar
SFA
Most have a male and female end and when plugged together complete the cicuit deleting the need for a key. But if you leave them plugged together the battery will drain down. A toggle switch could easily be used in place of the factory ignition.
Jmuddin284
Jan 19, 2026 07:16 AM
skinnyr6
Aug 25, 2023 02:18 AM
Desimation2k8
Jul 17, 2015 12:37 AM
Unzzy66
Jul 11, 2015 10:01 PM
cornermike
Jul 8, 2015 11:44 PM
