Speedo problem on 03 Trailblazer!
Old Dec 24, 2006 | 05:46 PM
alegend's Avatar
Default Speedo problem on 03 Trailblazer!
I'm attempting to install a factory speedometer on an 2003 Trailblazer, everything was hooked up according to the directions however its not working. The needle seems to be pulsing off the coil power but not reading the sensor from the wheel. The battery for the quad was dead when I bought it could this be the problem? Any suggestions/help would be appreciated. Merry Christmas....
Old Dec 25, 2006 | 11:31 PM
jta4455's Avatar
yes more than likely, adequate battery voltage is needed to run the speedo. I wouldn't suggest running it without a fully charged battery as you could fry the speedo because when power is generated the voltage in battery needs to be good otherwise it will apply too much voltage to headlights, taillights, speedo!!!
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
hondarider1234
Jul 21, 2015 11:53 PM
shewshew989
Jul 14, 2015 03:09 AM
shewshew989
Jul 14, 2015 02:54 AM
