Pull starter
Old Dec 28, 2006 | 08:48 PM
caperinmuskoka's Avatar
Ride like you own it, Not like it's stolen!
Default Pull starter
I have the factory seal (Metal clamp)still on my two Sportsman 450's ...My question is should I leave this alone or should I at least try it to see if it even works............I just don't want to be in the middle of the bush and my electric start will not turn over..........On the other hand I want to keep the factory seal on to keep it water tight.....Caper.............Thanks...
How many of you guys out there never used the pull start yet?
Or how many of you tried to use it and it was rusted or seized?
Old Jan 3, 2007 | 01:29 AM
STARKSREBEL's Avatar
use it and make sure it works.if you lose your starter or dead battery this is the only way to crank your bike.
Old Jan 3, 2007 | 07:40 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
hey caper, i havent used mine on my 800 yet lol. you pull yours if if you want it wouldnt anything. just make sure that you put it back securely and thats really the onlt seal you need.
Old Jan 3, 2007 | 10:37 AM
Haven't even given it a thought Caper. Now you have me curious. I'll wait until I need to though. But, I don't think it would be much of a problem. Looks pretty well sealed.
Old Jan 3, 2007 | 03:59 PM
if you are worred about it resealing dont be!polaris pull rope handles seal great thats whythey put the mtal ring on the handel.
Old Jan 5, 2007 | 11:44 AM
hdnvn's Avatar
I have an 03 Sportsman 500 with the pull start. Mines good but you have to play with it toi get it to retract. Have used it several times in that I have gone thru three starters in three years. Rust Rust Rust. Water was getting inside thru the starter attachment point where an O ring is supposed to keep it out. I ussed grease to seal it up by applying it to the area around the sarter gear just before inserting it into the housing. As well the housing on the pull start side of the machine dosnt even come with a gasket. Ihad to go to an earlier year and order it. Water was getting inside the housing regurarly and for all I know is still in there. Mt starter gear assembly sounds like complete crap when I start the machine, rattling all the time as if theres something loose in side. I have installed two of them in the life of the machine. As you might have guessed theres alot of water crossing going on in the riding that I do and eliminating that asspect of riding aint happening. Any advice about these water problems is welcome aside from telling me to quit riding in water...
Old Jan 5, 2007 | 12:53 PM
pull your pull rope assembly apart and clean it checking for dammaged parts.pull the starter as well.check the spring for dirt rust mud exc,make sure to lube it good with neverseaz,reasmble using rtv on starter and pullrope assembly to seal out water.
ghost civic
Jan 15, 2020 07:43 AM
Big bousse
Sep 26, 2015 10:42 AM
ScopeZ_
Jul 28, 2015 01:44 AM
ghost civic
Jul 19, 2015 10:13 AM
ghost civic
Jul 15, 2015 10:48 PM
