4x4 not working 01 magnum
Old Dec 29, 2006 | 06:32 PM
JimMQ's Avatar
Default 4x4 not working 01 magnum
The 4x4 on my magnum is not working. Here is what info I have already. On the handlebar switch I have key power on pin A. I have power to pin F when the reverse overide button is pushed in or the trans is in a forward gear.I have continuity between pin F and pin E when the switch is in the AWD position. I have 22 ohms resistance on both of the ft axle actuators. I purchased a new handlebar switch but had the same results. I have good contunuity in the wiring harness going up the handle bar. I need some good help on this one.
Old Dec 30, 2006 | 08:47 AM
Heinz01's Avatar
Hey Jim, Do you have oil in the front hubs? If not fill them at 3 or 9 oclock or slightly higher untill it gets through the bearings. I assume the AWD light lights up on the switch. If the light does not light up the "awd" will not work. Current needs to flow through bulb first. If this is all ok, take the hubs apart and check the coils for corosion. It's not to hard to takt them apart, just get a clean rag and sent everything in order the way you took it apart. OK good luck
Old Dec 30, 2006 | 10:06 AM
JimMQ's Avatar
The bulb does not light. This is an intermittant problem that finally acted up in the garage. I need this thing working before snow flys. Thanks for any help.
Old Dec 31, 2006 | 11:58 AM
bigike's Avatar
You could always just splice into your wires going to the hubs and put a switch to the battery just to get you buy until you see if it is a gear sensor, speed sensor or other problem.
Old Dec 31, 2006 | 01:48 PM
JimMQ's Avatar
As usual Its worling fine now after I did nothing. I bought a service book yesterday so next time it acts up I could ck it out better. Thanks for all the input. Ill have to make a jumper for just in case emergency.
Old Jun 25, 2007 | 10:41 PM
Motohoppie's Avatar
I had the same problem with my 01 sportsman. It turned out to be some bad wiring under the hood. I had to do some wire probing and found 2 bad spots close to the top of the steering post. It would sometimes work and sometimes not. I got it fixed before the snow fell! That was 8 monthes ago now I got new problems!
hugemoth
Jul 20, 2020 03:28 AM
timster911
Jul 13, 2015 01:57 PM
jettman
Jul 6, 2015 12:16 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
