Leaner fuel ratio
Old Dec 30, 2006 | 01:29 PM
ATVrider89's Avatar
Buy it now, explain it to the wife later!
Default Leaner fuel ratio
Thinking about going from 20:1 to a leaner mix of 32:1 for my 250r it says 20:1 on the gas tank but I hear many people run 32:1. The 20:1 seems to thick and it uses alot of oil. Anyone else here run a leaner fuel ratio?
Old Dec 30, 2006 | 02:08 PM
carlw's Avatar
no one runs 20:1
32:1 is the norm and 40:1 is also very common and is fine too.
the term lean is not realy the corect term . forget about the oil for a second, and think of it as adding more gas not putting less oil.
you will actualy be richer. lean and rich are ways to describe you fuel to air ratio. not the oil.
at 32:1 more fuel will be intering the engine through the carburetor jets than 20:1 so your fuel air mixture will be richer.
so you maybe able to drop a jet size when mixing at 32:1 and make some good power.
always look at the plug of corse but dont be suprised if it could use a smaller jet. jeting corctly is the only way to get all the power out of a motor.it may run fine after changing the oil mixture but it could be great with a jet change.
modern oil is better than the old stuff and the bike makers over jet them and want you to dump way to much oil in them also ,so the engine has a better shot at surviving any idiots abuse.
so first go to 32:1 oil mix then run it hard and check the plug. if its wet or rich looking drop a jet ,and check. keep droping until you make the most horse power "the bike pulls the hardest" then go up a jet size ,run it and check the plug.
Old Dec 30, 2006 | 05:57 PM
QWODER's Avatar
yea carlw is right.20:1 is to much oil.
Old Dec 30, 2006 | 07:24 PM
ATVrider89's Avatar
Yea I have been running amsoil 20:1 in there but I was down at the honda dealer yesterday and that guy recomended Honda's HP2 at 32:1 (1 pint to 4 gallons og gas) and I trust Honda's oil a little more seeing that they did make the machine. Anyways I thonk I'm gonna switch over to the HP2 in Spring.
Old Dec 31, 2006 | 03:11 PM
carlw's Avatar
KLOTZ R50 is a fine oil. it is the way to go.
ltrmc02
Aug 22, 2021 02:34 PM
SureCanUSA
Sep 14, 2015 09:57 AM
PrairieDog126
Sep 12, 2015 06:53 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Elkaholic
Sep 6, 2015 02:44 PM
