2004 AC 650 V-Twin blowing main fuse (30a)
Old Dec 30, 2006 | 07:48 PM
wa0989's Avatar
Default 2004 AC 650 V-Twin blowing main fuse (30a)
I have a problem. I just installed a winch & snow plow, now on occassion the quad blows the main 30 amp fuse & will only start with pull starter. Also it will only run for about 2 minutes with fuse blown & then dies. Any help would be great, thanks.
Old Dec 30, 2006 | 08:58 PM
LittleBill's Avatar
fix the wiring you added, which is what caused the problem
Old Dec 30, 2006 | 09:17 PM
wa0989's Avatar
Everything is by the book, unless there is a problem with the winch itself?
Old Dec 31, 2006 | 04:30 AM
Bear4570's Avatar
Well, look at it this way. The machine didn't blow fuses before your changes and now it does. So where would a logical person start looking for the trouble? That's right, at the last changes made. So start lookin".
Old Dec 31, 2006 | 05:00 PM
LittleBill's Avatar
its obviously not by the book if your blowing a fuse, which should have nothing to do with the winch, the winch should be fused completely seperate from the rest of the bike's electrical. remove the wiring from the winch and see if it blows if it doesn't which it prolly won't you still have a issue with the wiring you added, nothing we can tell you will help if you refuse to believe its something you did
Old Jan 2, 2007 | 11:11 AM
Catterman's Avatar
Got Milk!
Blaming Guns For Crime Is Like Blaming a Spoon for Rosie O'Donnell being Fat!
Are you sure it is your main fuse? If it does blow there is no way you can start it, or keep it running.
You probably have a short, I would start with your ground wire.
On another note, you should replace your main fuse with a mini circut breaker. They are a life saver and cost only $10 at NAPA. I also have one in for my fan fuse.
Old Jan 2, 2007 | 04:25 PM
oledad's Avatar
Only 2 causes, Short or you have wired it up wrong and are overloading the circuit. The winch should be wired thru the winch relay directly to the battery.
xreynolds95
Technical and How-To Articles
Nov 19, 2024 03:52 AM
MooseHenden
Family ATVing Photos
Oct 5, 2015 08:14 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
byronman
Sep 6, 2015 06:34 PM
