'06 Scrambler 500 Problem!
Old Jan 2, 2007 | 11:30 PM
alegend's Avatar
Default '06 Scrambler 500 Problem!
Anyone had problems with their scramblers, this quad was brand new and luckily still under warranty, when the chain popped due to the bearings failing. The dealer thought the chain was too tight, however it wasn't touched since dealer set-up. Just wanted to know if anyone else had problems witrh their new models.
Old Jan 3, 2007 | 01:40 AM
gr8one's Avatar
i got mine in oct and been loving it ever since haven't had any problem knock on wood.
Old Jan 3, 2007 | 02:33 AM
BigBlueScrammy's Avatar
Something similar has happened on a couple others that I am aware of. The axle retaining nut has work loose and ruined the bearings, carrier, chain and sprocket. They need to make sure and lock tight that thing.
Old Jan 3, 2007 | 10:15 AM
alegend's Avatar
This quad was purchased brand new on 5 Jul 06 letting it sneak in on the warranty. It has over 750 miles (the speed/odom kit was put on a few weeks after purchase. The dealer thought the chain was overtight, but bigbluescrammy's explanation seems more likely. Thanks for the replies.
Old Jan 3, 2007 | 02:18 PM
XpLo400's Avatar
when i got my 05 the chain was so tight you couldnt move it with your hands...I adjusted the chain right away.
Old Jan 3, 2007 | 09:24 PM
hikuntryslim's Avatar
5 months out axle bearing failure , in shop 3 weeks , 2 weeks out axle bearing failure again , out n running again fer 2 months ....
Old Jan 3, 2007 | 09:32 PM
alegend's Avatar
Any reason given for your bearing failures?
Old Jan 4, 2007 | 10:40 PM
no , they gave no good reason .
Old Jan 5, 2007 | 01:48 AM
STARKSREBEL's Avatar
failure do to not greasing the bearings properly.more than likely from dealership.
Cole Hadden
Jun 15, 2025 09:05 AM
1000gade
Jul 16, 2015 10:48 AM
maxjung
Jul 15, 2015 11:59 PM
maxjung
Jul 14, 2015 12:29 PM
maxjung
Jul 13, 2015 05:11 PM
