Blaster Oil Injection
Old Jan 3, 2007 | 12:16 PM
thelmuffinman32's Avatar
Default Blaster Oil Injection
Ok, so I know how the plastic gear in the oil injection system in Blasters is a problem so most opt for a delete kit. I'm wondering if there are any aftermarket companys who sell like a stronger version? I'm going to be buying an 01 blaster in a few days that has a few things done to it and I'm not sure if the injection is removed or not. So my question is: Does anyone have an aftermarket solution to keep the injection system? link?
Thanks
Old Jan 3, 2007 | 02:13 PM
kickass210's Avatar
http://www.rydindirty.com/thetruthaboutoilinjectio.htm
Old Jan 3, 2007 | 07:07 PM
Boomer2's Avatar
The Truth about Oil Injection
Here I made it so you can just click on it.
My 91 Blaster is still running oil injection with no problem. I think the key is that whenever I take the carb off to work onit I make sure and bleed the air out of the oil injection system, plus make sure the vent is clean on the oil tank. If I had a hopped up Blaster I would be afraid the extra power would destroy the plastic gear, or higher rpm would cause problems, but with a stock or mildly modded blaster I think the oil injection system is fine. Although any mechanical system isn't foolproof. In the back of mind I'm concerned that over time plastics weaken when exposed to heat and cold, maybe I will get a new gear, or maybe do some radical mods to the blaster that would warrant removing the oil injection.
Old Jan 3, 2007 | 11:48 PM
Wow, good thing I asked some people who know their stuff, thanks guys!
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
Ask the Editor
12
Jul 21, 2015 06:57 AM
