Raptor 350 needle
Thanks. I could of sworn there were only two adustments on the needle. Didn't know if I needed another needle. So when jetting I just need to move the stock clip to the lowest position on the stock needle and remove the plastic washer?
No not on the Raptor. The Raptor 350 only has 3 clip positions. Remember Speedy your Warrior does not have the same carb as the Raptor 350. The stock clip position is in the middle.
If you want to make it richer drop the clip to the bottom to raise the needle and if you want to make it leaner raise the clip to the top to drop the needle. If you are jetting start with the needle in the middle position till you get your main jets right. Then you can fine tune it with the needle clip position.
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
