Raptor 350 needle
Old Jan 6, 2007 | 12:19 AM
mm's Avatar
mm
Default Raptor 350 needle
Does anyone know the clip position on the stock needle of the Raptor 350 when jettting?
Old Jan 6, 2007 | 12:33 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
stock should be 3rd notch
Old Jan 6, 2007 | 02:01 AM
mm's Avatar
mm
Thanks. I could of sworn there were only two adustments on the needle. Didn't know if I needed another needle. So when jetting I just need to move the stock clip to the lowest position on the stock needle and remove the plastic washer?
Old Jan 6, 2007 | 11:16 AM
Evasiveone's Avatar
No not on the Raptor. The Raptor 350 only has 3 clip positions. Remember Speedy your Warrior does not have the same carb as the Raptor 350. The stock clip position is in the middle.
If you want to make it richer drop the clip to the bottom to raise the needle and if you want to make it leaner raise the clip to the top to drop the needle. If you are jetting start with the needle in the middle position till you get your main jets right. Then you can fine tune it with the needle clip position.
Old Jan 6, 2007 | 05:34 PM
Speedy2222's Avatar
stock jetting.. usually the needle is set to be in the middle
bmxatv10
Oct 14, 2022 06:23 PM
wrencher82
Sep 24, 2015 03:39 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
