Blaster oil block off kit
Old Jan 6, 2007 | 11:24 PM
tmzg29's Avatar
Default Blaster oil block off kit
First off you can bash me because I ride a Polaris. I just bought a blaster for my boy. I pulled the jug off to have it bored because it was only putting out 75 lbs of compression. I want to put an oil block off on it. I pulled the cover and removed the oil pump. How do I remove the shaft coming out of the motor to put the block off plate over the hole. My other question is what or how do I block off the oiling hose going to the carb. Do i just pull out the hose and plug it with something? I have wrenched on my Polaris alot but this is my first go around with the blaster.
Thanks,
Old Jan 7, 2007 | 11:50 AM
tmzg29's Avatar
come on guys........I know someone out there has put a oil block off kit on there blaster. Can someone help a brother out!!!!!!!
Old Jan 7, 2007 | 11:57 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
i wish i could but i've never seen a block off kit get put on..
Old Jan 7, 2007 | 12:42 PM
warriorryder's Avatar
you have to take the clutch cover off to pull out the gear and yes you plug the line going to the carb
Old Jan 7, 2007 | 07:07 PM
JLsparky7's Avatar
A little JB weld in the oil inlet for the carb works.
Old Jan 7, 2007 | 07:18 PM
tmzg29's Avatar
Thanks guys. I was hoping all I had to do is remove the clutch cover to get the shaft removed. I also thought about plugging the hole with JB weld but wanted to see how others plugged it. Pros and Cons. When I pick up the jug on Wednesday I will get the block off kit and also the new throttle cable and carb. top to remove the TORS.
ReconBayou
Oct 31, 2022 05:37 PM
LemonTea
2) Chassis problems..
Oct 2, 2015 03:50 PM
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
