Diesel gas in my atv
did u run it? if not just pull the rubber line goin from the gas on/off/reserve switch to ur carb and drain it. then pull ur carb out and clean it out. then fill ur tank up with regular let it slosh around in there and drain it. do that maby 2 times. thats what i would do. if u ran it just check ur plug and do that
well thats always good haha well the only thing you can really do is drain the whole gas tank, drain the carb and clean the carb, and see if she fires up...if it doesn't fire up you may have fouled a plug by running diesel so try getting a new plug in there and let us know if it works...wish ya luck
just put in a glow plug and keep runnin desiel [img]i/expressions/face-icon-small-happy.gif[/img]
accidenlty, accidentally, atv, blaster, diesel, fourwheeler, fuel, gas, mistake, poured, put, quad, ran, tank, yamaha
