06 wolverine 350 valve adj.
Old Jan 7, 2007 | 07:58 PM
Aokss's Avatar
Default 06 wolverine 350 valve adj.
hey everybody,
i'm needing to adj. my valves for my 06 wolverine 350. and i can't found a sevice manuel for my life on it.
anybody help me out on this?
Old Jan 8, 2007 | 06:08 AM
2FAST4URASS's Avatar
First off welcome to the forums..
How to check and maintain:
You will need:
17mm socket and ratchet set.
10 mm socket.
5mm allen wrech.
feeler guage set that has stock sizes (6-8 thousandths on the exhaust, 4-6 on the intake valve)(different if you have aftermarket cam, i set mine to what my engine builder says .003 intake and .004 on the exhaust)
BIG flat head screwdriver
4mm wrench
now youre ready.
Take off the crankcase timing mark cap, cam sprocket engine sidecover thing(on head), and valve covers.
Now while you have the socket on the bolt that is holding the cam sprocket on, spin the engine over with that while looking in the timing check hole on the crank. wait till the T (tdc) mark on the mag. lines up with the line on the case. The look up at youre cam sprocket and make sure that lines up with the line on the head. (make sure its a compression stroke).
Now while everythings lined up, take the 10mm and loosen the jamnuts on the tappits on the rocker arms. This will allow you to adjust the tappits up or down.
take youre feeler guage (stock specification clearance) and put it between the tappit and valve stem. then tighten the tappit down with the 4mm wrench and tighten the jamnut. Once done with both intake and exhaust valves, make sure jamnuts are TIGHT, and make sure you can fit the feeler guage you used back under the tappit but noting smaller or bigger.
Then put the valve covers, head side cover, case timing plug, and the tank back on and fire it up.
Unknown terms you might like to know (nooBs):
Tappit-called something else by yamaha....the bolt that is in the end of youre rocker arm once the valve cover is off....when engine is running it pushes down on valve stem...not hard to find.
Jamnut- the locknut that holds the tappit in place when tightened.
Feeler guages-like diff. thickness little paperlike stainless steel things used for measuring small clearances....will get pics of stuff next time i do mine.
Engine tdc: TDC means TOP DEAD CENTER. Its when youre piston is at the highest point in the combustion chamber it will ever get.
As for just checking them and possibly not having to adjust them:
Instead of loosening jamnut so you can adjust the tappit, just line all the markings up so the engine is tdc and then stick the specified thickness feeler guage between tappit and valve stem. make sure the right one fits. then see if a size bigger or smaller fits. if not, then youre in the clear (how i check mine).
Old Jan 9, 2007 | 07:44 PM
Aokss's Avatar
Hey First Off Thanks!!
2nd. Got the covers all off found the three timing marks im guessing TDC is the middle mark. and its on compression stroke, no T or anything just three marks. found mark on cam spocket and what it should line up with like a pointer made in to the casting sticking out. well..........know its lined up on middle mark below but not at the cam spocket. its like one tooth off. line up the mark on cam spocket the marks below are nowhere to be seen. like i said its a 06 bought it new and it has less then 300 miles on it im guess. so is it possible it can be out of time?? and no clearance at valve (only checked intake at this time).
soooo it needs to be set in time right?? how much trouble is this?
[img]i/expressions/face-icon-small-confused.gif[/img]
P.S. the chain is tight.
p.s.s. wheres a good place on the web to find a sevice maneul to buy ?
Old Jan 10, 2007 | 06:20 PM
Aokss's Avatar
bump
Old Jan 16, 2007 | 09:30 PM
Aokss's Avatar
any ideals?
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
