Tough enough to start a sub zero Grizzly!
I was intimidated by the pull start at first but decided what the heck I better figure out how to do this in case I get stuck in the woods with no battery.
I've found that if I pull just past the compression stroke prior to initiating my start pull I can pretty much get enough force to get the thing started on the first pull.
It took me a few times to figure it out (and an awful sore shoulder) but now I have no problems even in cold weather.
I'm not a small guy either so I guess that helps...
You might want to consider a compression release like some of the big 4 stroke 2 wheel bikes have.
The easiest way to start a quad in sub zero temps when the battery cannot turn it over is to have someone push the starter button while another person pulls the cord. In -40 temps, its about the only way to get a big bore 4stroke to go.
