help please bad or not
ok i have a 2005 blaster its bored,has pipe, wiseco piston,v force reeds nerf bars almost everything a racer would want ok i was riding today donign wheelies and tricks after i got off to see if the muffler was doign god since i repaced it i noticed drops on the ground i took some of the sand and it smelled like gas i check the tank and then i notice it is leaking from the breathers and where i live it is almost freezing so i was wonderign what could be causing tht
well if it was coming from the breathers that are connected to the carb u shouldn't have a problem because gas usually comes out of it when you do wheelies, if it was coming out when it was just sitting then your float could be getting stuck
