help please bad or not
Old Jan 13, 2007 | 08:06 PM
raceforfree's Avatar
Default help please bad or not
ok i have a 2005 blaster its bored,has pipe, wiseco piston,v force reeds nerf bars almost everything a racer would want ok i was riding today donign wheelies and tricks after i got off to see if the muffler was doign god since i repaced it i noticed drops on the ground i took some of the sand and it smelled like gas i check the tank and then i notice it is leaking from the breathers and where i live it is almost freezing so i was wonderign what could be causing tht
Old Jan 13, 2007 | 11:04 PM
RaptorRidn9000's Avatar
well if it was coming from the breathers that are connected to the carb u shouldn't have a problem because gas usually comes out of it when you do wheelies, if it was coming out when it was just sitting then your float could be getting stuck
Old Jan 14, 2007 | 12:12 AM
JLsparky7's Avatar
Yea, its just the wheelies. No worries. Thats the only reason id like a EFI bike cause that wont happen.
