Adding carb cleaner to gas??
Old Jan 17, 2007 | 08:36 PM
Ashleymc's Avatar
Default Adding carb cleaner to gas??
Honda 2002 foreman 450 owner..due to lack of use I had to have my carb cleaned by the dealer+battery charged+new gas...$165 later it starts and runs good since...My question is ..is it ok to add the concentrate carb/injector cleaner that i use occasionally for the truck in proper dosage?? does it do any good or harm? Also now i run premium gas,wondering if that helps anything?? Great Forum!!
Old Jan 17, 2007 | 09:20 PM
carlw's Avatar
I dont think you will see any damage from running carb cleaner in the gas. But i would not do it.
And you will make more horse power and burn cleaner with regular gas. These are low compresion engines ,So they require a lower octane fuel.
Old Jan 17, 2007 | 09:38 PM
Williebee's Avatar
I use seafoam in every tank of fuel it's a fuel cleaner/stabilizer that cleans the fuel system and also the combustion chamber , it's safe to use in any 2 or 4 cycle engine ; you can get the seafoam at O'Reallys, Auto zone and Advance Auto parts stores ! I get mine from O"Reallys for $4.99 + tax , it may be more or less according to your local ; it's the best thing i've ever used in over 20 years of small engine repair ! ...................williebee
Old Jan 17, 2007 | 11:12 PM
Fenton88's Avatar
gas line anti-freeze works great!
user493
Aug 13, 2015 12:54 PM
TheHood
Aug 8, 2015 05:49 PM
baysport
Jul 23, 2015 11:37 AM
Aitch
Jul 21, 2015 09:40 PM
