YAMAHA (Speciality) REPAIR TOOLS......HELP !!!
I went to Yamaha Dealer to price a :Clutch/Flywheel Removal Tool (Also Know As:Mag Holder......YU-01235/90890-01235.....Price $59.00 ............Also: Crankcase Separating Tool.......Yu-01135-A/90890-1135....Price $73.00......These tools will be used to work on a 1998 Yamaha Timberwolf 250 4x4.......These prices are unbelieveable aren't they !!!....Does anyone know of any aftermarket tools that can be purchased for a REASONABLE price that will work As Well as the OEM Tools ????? If you do or have another suggestion I would GREATLY appreciate hearing from you .....Sincerely, DeerMe
all the flywheel removal tool is just a 1 ft lever with 2 botls no the end to hold it.. and the sperating tool is prolly some type of pry par.. all you need is rubber hammer to knock is loose so u can pull them apart
The best clutch holding tool you have is your rear brake. Just have a friend sit on the quad and hold the brakes and the clutch nut will come right off with a breaker bar. Its torqued at around 50ft/lbs I believe.
Speedy2222 - JL Sparky 7 and Atv_Man....Thank You for your suggestions and comments. With the weather this bad I will be taking this motor apart on my work bench. I do not have a air compressor so an impact wrench is out. Ebay had a Clutch/flywheel tool that is suppose to work on Yamaha and Honda engines. It looks like a pair of channel lock pliers with a short bar on the end with 2 pins attached.Does this tool sound famaliar and has anybody used one ? It does not seem very long so I don't think it will have much leverage with breaking bolts loose....any other ideas ???
Well I am not a welder but If I had a good picture with an accurate drawing I'm sure I could get someone to do it for me!!
well i can give u an estiamte(close) but i can't give u an approximate size... but i will try and take a pic for u and get some estimates
As for removing the clutch, You can use some of the tricks brought up here.. if the motor is still in the frame the brakes work nice to hold it. The fancy holding tool does help you get a good torque on the nut when re-installing it though.
Are you sure you have to take the crankcases apart? does it not shift or something?
