YAMAHA (Speciality) REPAIR TOOLS......HELP !!!
Old Jan 26, 2007 | 07:08 PM
DeerMe's Avatar
Default YAMAHA (Speciality) REPAIR TOOLS......HELP !!!
rruser - Yes the engine has to come out and be split apart. The tranny just started "Jumping" out of gear when you put a load on it ! I will pull the engine and then take it apart on the work bench in the house. I'm trying to find a aftermarket company That sells these speciality tools similar to the OEM tools the Yamaha dealer want' to sell me !!!
Old Jan 26, 2007 | 07:11 PM
DeerMe's Avatar
hookinup - Sorry I can't help with Warrior questions. I don't own one...only use the picture in my profile !!!
Old Jan 26, 2007 | 07:20 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
i am not saying it says "use yamaha crowbar" but i am saying it is most likely along those lines...
Old Jan 26, 2007 | 07:27 PM
rruser's Avatar
A crankcase splitting tool looks more like a adjustable harmonic balancer puller. You might be able to use a rubber strap wrench to hold the flywheel when taking the clutch nut on/off.. but I have never tried this before.
-- I'm not trying to be mean to you speedy. You are always up for helping people and thats a good thing. If you are not 100% about something, do some research about it then post your findings. Thats the whole idea.. to share. I'm not trying to say you HAVE to use the correct tools for everything.. But you do have to know how they work in the first place so you can improvise without causing problems.
Old Jan 26, 2010 | 07:55 PM
  #15
wolfshowl28's Avatar
Default taking secondary clutch off of moto 4 (yfm)
There are many ways without the special tool. The impact wrench usaully puts enough zip on the nut to knock it loose but NO NOT hold clutch with your hands while using one. Putting the bike in gear and holding the rear brake will work if you have brakes. If you dont have a impact wrench and rear brakes a sure way is to take the swingarm off with the rest of the rear end (leave rear shock attatched at the top) and stick a flathead screwdriver through the hole of the frame where the swingarm was attatched to and slide it through the yoke and u-joint. put the bike in gear and slowly build up enough torque to knock it loose with a 23 or 24 mm socket. simple.
Old Jan 26, 2010 | 08:17 PM
  #16
one thing i forgot to mention is make sure the lock washer tab around the nut is flatend out and you should always use a new lock washer when reassembling. and before you go and tear it apart make sure you are useing the right wieght oil. To heavy like a 30w50 espeicialy in colder weather will cuase your clutch to skip. so drain the oil and put in some fresh 5w30 in the winter or 20w40 in the summer.if it doesnt correct the problem then it might be worn plates or other issues.
Old Jan 29, 2010 | 06:48 PM
  #17
Terrellster's Avatar
I know I'm a little late, but I should mention the homemade version of a strap wrench works too..... I use a used up Serpentine belt cut and screwed to a wooden lever..... if you do it right, it will be usable for things a s big around as you wish..... As long as the lever will handle it.
Old Feb 1, 2010 | 12:38 AM
  #18
Malachi's Avatar
Tusk makes these same tools for a bit cheaper. Probably not the same quality, but if your not using it everyday then they will do in a pinch. Can check Rocky mountain or Dennis Kirk for them.
toonces
Oct 16, 2019 12:11 PM
merryman
Jan 19, 2016 04:29 AM
kester_holmes
Sep 10, 2015 08:27 AM
Aug 28, 2015 09:33 AM
greek271
Aug 8, 2015 08:16 PM
