Warrior 350 starting
Old Jan 27, 2007 | 04:04 PM
soccerboy's Avatar
Default Warrior 350 starting
I have a 91 350 warrior that will not start without the battery charger connected to it for about 10 minutes. Has new battery. It turns over fine but just floods out and never catches. Leave it set for 15 minutes with battery charger on and it will fire up and continue to start unassisted as long as it does not sit for more then two hours. No measurable drain on battery when the key switch is off. HELP>>>
Old Jan 27, 2007 | 04:06 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
stock warrior carbs don't flood easily.. has it been jetted or does it have any mods?
what kind of battery did u get for it?
only thing i can think of to have u try is switching batts with soemone else to see if it still does it or if it stops
Old Jan 27, 2007 | 04:12 PM
Oddy's Avatar
yea or take the battery back and if its from autozone or something theyll test it if it just needs a charge theyll charge it if its bad u can get another 1 for free i had that happen and i found out the battery was just trash off the shelf
Old Jan 27, 2007 | 04:16 PM
soccerboy's Avatar
no mods accept 10 overbore with wisco pistion. Nothing done to the carb. Battery is Yuasa YB12CA. Both batteries are really new and both act the same way. The charger puts out almost 13 volts when its on the battery but nothing makes sense. Why will it start without assist when it is warm?
Old Jan 27, 2007 | 04:17 PM
Speedy2222's Avatar
i'm gonna go on a limb and say.. soemthing is corroded or out of spec and when it gets hot/warm it gets in tollerance or enough to pass the current to make it run
Old Jan 27, 2007 | 04:21 PM
soccerboy's Avatar
That was something I thought about also. Maybe I will just have to keep the charger handy.
Old Jan 27, 2007 | 04:22 PM
Speedy2222's Avatar
if u have aim i will send u some wiring shcematics
Old Jan 27, 2007 | 04:27 PM
soccerboy's Avatar
I am cool. I have all the manuals and schematics. Their are no specs on the current draw of the starter but I know it is over 10amps when it is cranking. I thought maybe the starter drew the battery down when it was cranking and that made the CDI not fire correctly but I can not find the correct specs on the current a good starter will draw and I really do not want to buy a new starter to swap it out.
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
1000gade
May 27, 2015 12:37 PM
dunc_n
Aug 26, 1999 09:32 PM
