Explorer 400 clutch problems
Old Jan 27, 2007 | 04:32 PM
maubele's Avatar
Default Explorer 400 clutch problems
I have a 1998 400 explorer and i am going through belts about every 300 hrs!!!!! I also have a 2003 sportsman 500 and don't have any problems. Any suggestions?
Old Jan 27, 2007 | 05:44 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
thats alot of miles in 300 hrs of service. is burning the belt or shredding it?
Old Jan 27, 2007 | 06:02 PM
maubele's Avatar
Sorry, i must have had a brain let down, I meant 300 miles, not hours. And it's not shreading or chunking them, it is creating fine rubber powder. The belt doesn't have any chunks out of it. It looks fine, just narrower.
Old Jan 27, 2007 | 07:50 PM
jta4455's Avatar
check clutch offset, motor mounts, bushings in both clutches, buttons in both clutches. probably need a rebuild. and also keep in mind that you have almost the same amount of horsepower out of a 500 lb machine (xplorer) than you with your 700 lb 500 sportsman. any speeds 0 to 15 mph use low range and above 15 high. You may have a groove starting in your drive clutch. I have a 99 xplorer 400 and love it.
Old Jan 27, 2007 | 07:51 PM
ftwflh's Avatar
Check your secondary clutch it could have a worn helex or buttons.Also make sure your air ducts are not plugged.Sounds like you have a heat build up situation
Old Jan 27, 2007 | 08:42 PM
stendori's Avatar
Super Quad Patrol
I'm watching you!
yea both of them are great things to look for.
skinnyr6
Aug 25, 2023 02:18 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
Wnthunting
Jul 9, 2015 03:02 PM
cornermike
Jul 8, 2015 11:44 PM
