griz 660 diff lock
I have a 2005 Grizzley that the Diff lock light flashes when I engage it but the diff lock will not engage. I have checked all the relays and wiring harnesses from the diff servo to the relays. I have tested the servo also. If i Jump the 4 wheel #3 relay diff lock engages and the light stays on (like it is supposed to) i tested the relay and tested fine but I even replaced it and still the light flashes and doesn't engage. Any ideas?
i have an 03 660 that did that on a good friday ride i rocked the atv back and fourth from drive to reverse a couple times and it engaged i think that there some how getting off a tooth or two on the slide gear in the diff its plastic
When engaging the diff-lock if at all possible don't be in the muck, make sure you have the front wheels straight and you should be good.
One way to REALLY test this is to jack up the whole quad so that all 4 wheels are off the ground and the QUAD is supported so it won't fall on you! Engage the Diff lock and see if the light continues to blink.
John Reed
Sep 9, 2015 03:46 AM
