griz 660 diff lock
Old Jan 28, 2007 | 11:15 PM
m954rrider's Avatar
Default griz 660 diff lock
I have a 2005 Grizzley that the Diff lock light flashes when I engage it but the diff lock will not engage. I have checked all the relays and wiring harnesses from the diff servo to the relays. I have tested the servo also. If i Jump the 4 wheel #3 relay diff lock engages and the light stays on (like it is supposed to) i tested the relay and tested fine but I even replaced it and still the light flashes and doesn't engage. Any ideas?
Old Jan 29, 2007 | 10:51 PM
Mubpuppy's Avatar
I also have a 04' grizz that does the same thing. If you find out any info please tell me.
Old Apr 9, 2009 | 04:34 PM
fatbatster's Avatar
Has anyone had any luck fixing this? My 2002 is doing the same thing.
Old Apr 11, 2009 | 08:37 PM
adjdrobertson's Avatar
i have an 03 660 that did that on a good friday ride i rocked the atv back and fourth from drive to reverse a couple times and it engaged i think that there some how getting off a tooth or two on the slide gear in the diff its plastic
Old Apr 15, 2009 | 08:00 AM
CraZySteve's Avatar
If the light is blinking it means that the Diff is not locked! Simply do what adjdroberton did -- rock it a little and you should be good.
When engaging the diff-lock if at all possible don't be in the muck, make sure you have the front wheels straight and you should be good.
One way to REALLY test this is to jack up the whole quad so that all 4 wheels are off the ground and the QUAD is supported so it won't fall on you! Engage the Diff lock and see if the light continues to blink.
Old Apr 16, 2009 | 08:42 AM
Deer Slayer's Avatar
the tooth on the slide gear is off just pull the servo off and check it out its an easy fix
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
John Reed
Sep 9, 2015 03:46 AM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
panicmanic
Aug 25, 2015 09:10 AM
