2wd Rancher Tire help?
Old Jan 29, 2007 | 12:14 AM
clint6760's Avatar
Default 2wd Rancher Tire help?
It is time to get new tires on my 06 2wd rancher and I am needing some help. I would rather keep the stock rims but I might end up getting some ITP steel wheels. I would like to go up to 26" but I don't want to lose hardly any power, none preferably. But looking on rockymountainatv.com, It seems that almost all the tires for a rancher on the front are just 25" or lower. Which the stock are 24" in front and 25" in rear, so would going 26" in rear and 25" in front be ok or should I try to find all 26" or 25". The only reason I'm wanting 26" is for the extra ground clearance and the deeper tread seeing as all the 25"s tread is under an inch. So any suggestions on if I should stick with all 25" or would it be ok to go to 26" or a mix between both. Thanks
Old Jan 29, 2007 | 12:19 AM
maddog56's Avatar
You can get the deep tread on the 25" mudlite.
Old Jan 29, 2007 | 09:22 AM
mykool61679's Avatar
get 26 inch gators or mud bugs for stock rims. if you change your rims i would say outlaws for sure. i too have a two wheel drive(with a couple goodies) it turns 26s fine, you will loose abou 5-6 mph off your topp end if that matters. as soon as i get a lift kit im going to 27s!!! cant wait. hell if i cant drive across it ill betcha i can float!lol.
Old Jan 29, 2007 | 12:34 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
I have come around to the point of view that is doesn't make any sense to buy a nice nimble great handling little trail machine and saddle it with huge tires that it was never meant to have! If you genuinely need huge tires for clearance or whatever, it's time to step up to a larger machine that can handle them,
Old Jan 29, 2007 | 01:19 PM
clint6760's Avatar
Yeah I don't really want to change much on handling and power loss. I probably will just go with 25" mudlites xl all the way around with some new itp steel rims. Sound ok?
Old Jan 29, 2007 | 03:24 PM
clint6760's Avatar
I am going to go with 25" mudlite xl's all the way around with itp steel wheels. I'm going to go with a 25x8-12 in the front. Should I go with a 25x12-12 in the back or a 25x10-12. Stock rear is 25x11-10. Thanks
Old Jan 30, 2007 | 03:06 AM
clint6760's Avatar
Anybody?
Old Jan 30, 2007 | 02:07 PM
imo, i dont like mud lights! the name is misleading, they should be called trail-lights. they are soft rubber, which if you ride alot of black top they will wear bad. they are a descent tire. the ride good on the trails, but nothing special in the mud. if weight is a big factor, or top end i say go for it, but if not i think you would be happier with a bug or gator. maybe even a swamp-light? and in reply to rr, i do need the ground clearance, and i have enough motor to turn 27s ,so why not? i would love to own a bigger machine its just not in the cards right now!!
Old Jan 30, 2007 | 07:10 PM
aaaaaaa's Avatar
im also thinking of getting new tires and im going to stick with the mudlite tires and not loose too much power.
Old Jan 30, 2007 | 08:18 PM
clint6760's Avatar
Do yall think I should go with 12" wide on the back or 10"?
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
black_thunder
Sep 20, 2015 10:21 PM
rgjackson
Sep 17, 2015 11:21 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
