How does the 4x4 work through the speedometer
Old Jan 29, 2007 | 11:49 PM
2002sportsman's Avatar
Default How does the 4x4 work through the speedometer
I have a 2002 sportsman that im putting together and the speedo dont work. I have the suspension off so I cant see if the 4 wheel drive works yet, but with the quad running nuthing lights up and the needle is on the wrong side of the button. Ive read that the 4 wheel drive works through the speedo if the other sutff is not working I assume the 4 wheel drive wont either, am I right? [img]i/expressions/face-icon-small-confused.gif[/img]
Old Jan 30, 2007 | 12:12 AM
GarryESE's Avatar
If the speedo is not working, the AWD may or may not work; depends on what has failed in the speedo.
Old Jan 30, 2007 | 08:32 AM
stendori's Avatar
Super Quad Patrol
I'm watching you!
the speedometer does control the awd in most of the new ones i beleave.
Old Jan 31, 2007 | 01:00 AM
jta4455's Avatar
Unfortunately you are right and you will have to come up with approx 300 bucks cause your speedo is bad [img]i/expressions/face-icon-small-sad.gif[/img]
Old Jan 31, 2007 | 10:00 PM
Freedom500's Avatar
The speedometer only supplies the negative connection for the 4X4 system. This is a safety feature that only lets the 4X4 system turn on if the RPMs are low enough (about 12 MPH in high gear). You can easily bypass the speedometer by tying one wire to ground but you give up the safety feature.
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
