98 Scrambler 400 issues
Old Jan 30, 2007 | 10:53 PM
Katy's Avatar
Default 98 Scrambler 400 issues
Hello, new to the forums. We have a 98 Scrambler 400 4X4 that has at minimum a wiring problem. Does anyone have a manual or a wiring diagram? The wires to the stator have been cut and spliced (incorrectly) to a small black box in the front and some others are just hanging there. We were told we needed a new stator or a new wiring harness. I could get a stator off of ebay but not sure which one is correct for my ATV or what all is needed. Any help would be greatly appreciated! I have searched for a manual but clymers doesn't make one for the 98 and I can't locate an OE service manual. Thanks for the help!
Old Jan 31, 2007 | 12:15 AM
jta4455's Avatar
contact your local polaris dealer, they should have one for ya. Or they should be more than happy to answer your questions.
Old Jan 31, 2007 | 12:33 AM
Katy's Avatar
Hey thanks for the reply. None of my local Polaris dealers have one instock but they will happily order one for $100 and it will take two weeks. Almost forgot one dealer wants $82.50 but they aren't sure when it will be in. As far as help the people that I talked to weren't real helpful.
Old Jan 31, 2007 | 12:39 AM
jta4455's Avatar
If you can't find a manual, try to locate all the wires and just corrospond the right ones and solder them together. I know this isn't an easy fix so I wish you luck. That sucks about your dealership not wanting to help you. The first impressions are always the biggest.
Old Jan 31, 2007 | 01:15 AM
Katy's Avatar
I would but I think the stator is the wrong one. The guy I got it from said he thought the stator was from a different year like a 96 or 97. I have a few wires left over. What is the small black box 2X2? It has 5 wires out of it and the stator has 7 wires. The ones that matched up are already matched but a few yellow ones I am not sure about. Any clue? Thanks for the reply.
Old Jan 31, 2007 | 11:39 AM
conig's Avatar
one of those black boxes is the voltage regulator and one is a rev limiter. 82.50 is cheap for a stator imo.
Old Jan 31, 2007 | 02:04 PM
Whitedog's Avatar
I think he may be speaking about the manual for 82.00
If you dont get a manual we can help ya get it wired up. The yellow, and the yellow/red should go to the voltage regulator. (the flat black box) to the right - if your facing the front of the quad.
Do you have a pannel style terminal board under your hood?
What other wires do you have hanging loose from the stator? Does the atv run?
Old Jan 31, 2007 | 06:08 PM
Katy's Avatar
Hey guys, okay. Lets see, yes I was talking about a manual. The cheapest we have found a stator for is on ebay for $128 buy it now. I looked at mine and compared the one on the 98 Scrambler (from ebay) and it "looked" the same however I couldn't see the color of the wires or how many there were. This is what I have out of the stator.......
Yellow connected to circuit board (yel)
Yellow/Brown Stripe not connected
Yellow/Red Stripe connected to circuit board (yel/red)
Black/Red Stripe ------ CDI
Brown ------ CDI
White ------- CDI
White/Red Stripe ------- not connected
Red ------- not connected
The CDI has 5 wires out of it as follows:
Blue connected to coil
Black connected to circuit board (left side)
White connected to white from Stator
Black/Red stripe connected to same on Stator
Brown/White stripe connected to Brown on Stator
The CDI box has a # on it CU2515
4AO5
EC38PL
Stator just has FF95 stamped on it..
Hopefully this will help you guys help me figure this out. Thanks again!
Old Jan 31, 2007 | 08:20 PM
Katy's Avatar
Well, as luck has it, I just found out that I have a stator and flywheel from a utility quad. Ya me....At least I know why the wires don't match!
Old Jan 31, 2007 | 11:34 PM
Whitedog's Avatar
Hmmmm.... Yea, you kinda threw me with yellow/brown, from stator. How did you discover this?
