Rubicon headlight
Old Dec 15, 2000 | 12:03 PM
Bis's Avatar
Bis
Anyone modify the handlebar light so you can shut it off while leaving the headlights on? It's a little annoying when you're carrying a load on the front racks at night.
Old Dec 15, 2000 | 10:49 PM
P.J.'s Avatar
It's as simple as splicing a switch inline with the wire leading to the lamp in the headlight housing.
Old Dec 18, 2000 | 08:43 AM
Rubidude's Avatar
I did this mod to my Rubi, as well as my 450. It really does help when carrying anything large on the front rack. Easy to do. There are two wires coming from the headlight...a brown one and a green one. I spliced into the brown one with a small toggle switch, and covered it with a waterproof cover.
Old Dec 19, 2000 | 05:22 AM
trailboss450's Avatar
25 Year Member
I also put in a toggle switch like the others. I mounted mine in the bottom of the headlight pod and used a waterproof boot on the switch. Only needed about 6 inches of wire and its all contained inside the pod.
Whitelx1
Oct 2, 2015 10:55 PM
PrairieDog126
Sep 16, 2015 01:33 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
