scrambler oil leak
Old Feb 1, 2007 | 05:40 PM
scrammersam's Avatar
Default scrambler oil leak
i found some oil leaked on the inside front rim. i first thought it was the rear seal, so i pulled the hub off and the seal looks fine and there is no oil on disk either. then i thought it could be brake fluid, but its not. could it be leaking from the balljoint/a-arm connection? im very puzzled on this one, any helps appreciated
Old Feb 1, 2007 | 06:11 PM
la90043's Avatar
CAN BE OIL/GREASE THAT YOU PICKED UP FROM THE GROUND SOMEWHERE.....OR MAYBE SOMEONE GOT A HOLD OF YOUR OIL CAN SQUIRTER AND HAD A MISFIRE......
Old Feb 1, 2007 | 06:21 PM
nope, not that
Old Feb 1, 2007 | 06:25 PM
la90043's Avatar
chain lube got warm/hot and flew over to the front hub while you where fish tailing or doing donuts...
Old Feb 1, 2007 | 06:34 PM
lmfao
Old Feb 1, 2007 | 10:20 PM
ahicks's Avatar
You say rear seal, there are 2 on a 4x4. There's a inside seal on the hub, and another on the inside of the strut (near cv joint). In the process of changing this one out now. Was doing the same thing you are talking about. Making a mess on the bottom of the strut, then dripping from there on the inside of the front wheel.
Old Feb 1, 2007 | 10:33 PM
perfect, thanks. just gotta tear into it more now
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
wrencher82
Sep 24, 2015 03:39 PM
