Honda "Sport" ATV Specifications Comparison
Old Dec 15, 2000 | 01:45 PM
DSAPP's Avatar
HONDA “SPORT” ATV PERFORMANCE SPECIFIACTIONS COMPARISON
250EX 250X 250R 300EX 400EX
Horsepower/RPM 17.6@5.6k 19.2@6.3k 39.8@7.4k 20.4@6.5 29.6@6.8k
Top Speed (mph) 50 52 68 54 65
Engine Size (cc) 229 246 246 282 397
Engine Type 4-stroke 4-stroke 2-stroke 4-stroke 4-stroke
Head/Cam OHV SOHC N/A SOHC RFVC
Valves 2 4 N/A 4 4
Carburetor Size (mm) 22 36 34 32 35.5
Clutch Automatic Manual Manual Manual Manual
Transmission 5-speed 5-speed 6-speed 5-speed 5-speed
Reverse yes yes no yes no
Front Suspension Travel 5.9 6.7 7.9 6.7 8.2
Rear Suspension Travel 5.7 7.9 9.1 7.9 9.1
Dry Weight 349 361 328 377 375
Length/Width/Height 68/42/42 68/44/43 72/45/42 68/44/43 72/45/44
Ground Clearance 5.9 4.9 4.3 4.9 4.3
Rear Tires 22x10 22x10 20x10 22x10 20x10
Electric Start yes no no yes yes
Year of Production 01- 87-92 86-89 93- 98-
Old Dec 15, 2000 | 04:38 PM
GR8T250R's Avatar
How did you get all these specs? Do you know specs on ATC 350X[h.p.,topspeed,susp. trav.]? I don't want to be picky,but a 250R is not an SOHC and does not have four valves. Just kiddin' around. Great post!
Old Dec 15, 2000 | 04:54 PM
retro's Avatar
Also, the 250r has a 34mm carb. Are those HP ratings at the rear wheel or at the crank? 40 HP sounds a little high?
ERIC
Old Dec 15, 2000 | 06:42 PM
garyc660R's Avatar
All of those numbers appear to be at the crank It is common knowledge after seeing countless dyno graphs over the years that the stock 250r had right around 29-32hp. Years ago, I looked into a 300ex (only 282cc) and it has about 13hp and they hav'nt changed. Good info still.
Old Dec 15, 2000 | 07:55 PM
Diogenes's Avatar
If I missed the response, please direct me to it. Someone asked about the source of the information. I would be interested in where the horsepower data comes from (not that I doubt it).
Useful and interesting information.
Someone else already mentioned the 250R is a two-stroke, with zero valves and no cam of any sort; you could use the "Edit" button and correct the otherwise excellent chart.
Diogenes
Old Dec 15, 2000 | 08:08 PM
94DGblaster's Avatar
nice chart..you should cook up some HTML and put it on a page
Old Dec 15, 2000 | 09:08 PM
Expeditioneer's Avatar
Uhhhhh, excuse me, but 2 stroke engines do not utilize cams, so you may want to edit out "SOHC" under the 250R engine. I'm not trying to be smart here, but we don't want such misinformation propagated now, do we??
Rest of the chart looks good, at first glance. Nice job.
RickyMac
Mar 5, 2016 07:27 AM
Asaran
Oct 8, 2015 11:14 AM
DFWSRT8
Aug 20, 2015 09:24 AM
HYS
Aug 18, 2015 12:28 PM
John Boy
Jul 13, 2015 11:16 AM
