Serious skid plate issues
Old Feb 6, 2007 | 04:34 PM
natedawgls's Avatar
Default Serious skid plate issues
okay so ive tried every thign i can think of but heres my problem on my 660 i need to remove my full engine skid plate but of coarse the bolts that hold it on are allen key heads (dumb) so i used a little wd40 let it sit for a few hours try to remove them and the stripped so i busted out the dremel and cut slots across the to try to remove them with a flathead to no avail. so then i heated them up and tried again but no luck if any one has any idea please help me out.
nate
Old Feb 6, 2007 | 05:42 PM
JLsparky7's Avatar
Go to any hardware store and buy a set of "easy out" drillbits. Itll cost you 10 bucks or so and save you a ton of headace. Its basically a drill bit designed to turn left instead of right that grabs the head of the screw.
Those will more than likely work. If not you can always just drill the head of the screw off, take the plate off, then remove the rest of the screw with some vice grips.
Old Feb 7, 2007 | 06:36 PM
velocyraptor's Avatar
yup
COFatboy
May 2, 2020 12:06 AM
Nondem
Feb 22, 2020 12:20 PM
Reactant
Jul 27, 2015 07:45 PM
95wolv
Jul 21, 2015 12:25 PM
Unzzy66
Jul 11, 2015 10:01 PM
