scrambler 500 white bros.pipe
Old Feb 10, 2007 | 08:50 PM
ltdaddyo's Avatar
Default scrambler 500 white bros.pipe
hey. has anyone had a problem with the white e series slip on? every time i install it,the front seal on the head pipe just wont seal ,an I always get a small leak causing it to backfire,when I install the stocker,its fine no leak. when I install the white,no matter how I adjust it,same s#!@.. does anyone know a fix for this??? any input would be very helpful.
Old Feb 10, 2007 | 09:01 PM
scramblerXrated's Avatar
i had this problem when i had a white bros too... i found that was because the pipe where it bends to go back to the silencer, had become warped or something. i was thinking it was because of the pipe, when hot getting hit with water might have caused it to warp little by little over the years. so i removed the stock pipe and clamped it into a bench vise. then took a pipe for leverage that just fit inside the exhaust pipe, and tweaked it until it fit the head pipe angle again. i think i also tweaked the head pipe too... worked great after that!
oh i also replaced the donut there at the same time to help,....
hope this helps...
X
Old Feb 10, 2007 | 09:10 PM
ltdaddyo's Avatar
thanks ill try that. did you use the existing stock spacers to mount it?
Old Feb 10, 2007 | 10:43 PM
i think the white bros came with some 3/8 spacers if i remember right,,,
X
Pehter
Oct 3, 2024 11:00 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Whitelx1
Oct 2, 2015 10:55 PM
Matt123
Sep 29, 2015 01:29 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
