400 foreman needs heavier rear spring
Old Feb 15, 2007 | 11:28 AM
blacksheep10's Avatar
Default 400 foreman needs heavier rear spring
My father in law has a honda 400 foreman that serves as his legs, he is a disabled firefighter and needs to get around his farm to chore. He weighs in at just under 300 lbs, and the rear wants to bottom on him at any kind of speed when he hits a bump. he was wondering if there is a heavier spring available, or what the factory spring rate and length was on the rear sping as I can get eibach springs at a good rate (I am into rock crawlers, have a coilover supplier). If I knew the factory length and rate, I could bump the rate up a bit and install for a little bit of nothing.
thank you in advance for all you help
Kelly
Old Feb 15, 2007 | 02:01 PM
mykool61679's Avatar
a high lifter spring increases weight capisity an extra 100 pounds.( more than NEW stock springs). i think ther only a round 30$$ a piece! order one for the rear or three for all the way around! it should help a lot! they also sell the tool to put the springs on! i think you can get the whole kit for 125$$. i think!
greg74
Sep 10, 2019 03:03 PM
Kodiak-vic
Jul 29, 2015 03:06 AM
Jul 22, 2015 05:00 AM
coolguy420
Jul 10, 2015 01:17 AM
Wnthunting
Jul 9, 2015 03:02 PM
