just finished my subframe
Old Feb 16, 2007 | 08:12 PM
supersonictoys's Avatar
Default just finished my subframe
just finished my chromolly subframe, havent sanded it yet or anything. just finished welding it and ran in the house and snapped a couple pics. the flash made it look crappy but you will get the idea. you would think the stock subframe is realy heavy but its actually only 14lbs. my new one is 6lbs. alot of work for 8 lousy pounds saved but it will look really cool once its powdercouted bright red! my photo bucket page
Old Feb 16, 2007 | 08:16 PM
Majorecho's Avatar
wow that was a big undertaking, seeing how you are so weight conscious on this build are you going with a titanium exhaust system too?
Old Feb 16, 2007 | 09:16 PM
no sir, my entire exhaust will consist of a 6 inch long header , a t3 turbo and about 5 inches of big strait pipe!
Old Feb 16, 2007 | 09:27 PM
shmee's Avatar
very nice!
Old Feb 16, 2007 | 09:36 PM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
Looks good! Hey every pound you shave off is that much less you have to launch or push up the hill.
Old Feb 16, 2007 | 09:39 PM
UBETRUN's Avatar
That looks great! What kind of bender did you use and where did you get the flat section with all the holes?
Old Feb 16, 2007 | 10:04 PM
thanks guys, took me about 8hrs so figure a pound an hour! LOL . well I have a 3/4 hand tubing bender that I used but I had to heat the tubing up a bit to get it to bend, guess because it was chromolly. either that or I' a pu$$y. that piece with the holes was just a piece of flat strap steel that drilled a pattern into with the drill press.
Old Feb 16, 2007 | 11:17 PM
HeadsupRacing's Avatar
Looks good.
Our chromoly ones are under 4lbs.
Aluminum is 1.5lbs.
Old Feb 17, 2007 | 12:36 AM
can I see a pic of one of yours in chromolly? you must be using some thin material. I used .065 wall.
Customer Service #1
May 15, 2020 08:46 AM
kbazzy
Sep 26, 2015 11:26 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Ridgerunner665
Sep 15, 2015 01:20 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
