question on changing a sproket
Old Feb 17, 2007 | 10:46 PM
2006ds650xrider's Avatar
Default question on changing a sproket
i wanted to know if u change the sprocket if u had to change the chain
or do any thing but change the sprocket?
thx
Old Feb 17, 2007 | 11:23 PM
cynick's Avatar
Nope, no change in chain unless you go down to 14 in the front, then just take out 1 link.
Old Feb 17, 2007 | 11:26 PM
ok thanks i was kinda worried
Old Feb 17, 2007 | 11:28 PM
oh do i need a chain breaker or a special tool
Old Feb 17, 2007 | 11:37 PM
cynick's Avatar
So are you putting a 14 tooth on the front? When I put mine on I had to grind off a link for a master, does your chain have a master link?
So to answer your question no you do not need a breaker, just a grinder, but they do help to remove the link. You can get em from Rockymountain for under $20.00 .
Seth
Old Feb 17, 2007 | 11:49 PM
no im just putting on a 15 tooth.
and i havent really looked to see if there is a master link.
if there is which side will it be on?
Old Feb 18, 2007 | 12:05 AM
cynick's Avatar
The clip on the master link should be on the inside, but since you are only going yo a 15 tooth you should be ok, I also ran a 15 for a long time. But when 2nd gear started slipping I had to gear down to use 3rd when hillshooting. After my build I will be putting a15 tooth back on.
Old Feb 18, 2007 | 12:07 AM
ok man thanks for the help
Old Feb 18, 2007 | 12:09 AM
cynick's Avatar
No problem. Glad to help.
Old Feb 18, 2007 | 09:48 AM
KaylasDaddy's Avatar
Has been riding one thing or another since I was 11 years old.(31 years).
if you are useing a 15 tooth up front you should not have to shorten the chain at all.... I didn't. if you put the master link you MAY want to get an extra one or at least the retaining clip as i wasted mine getting it off the first time.
