Rincon leaking coolant
Old Feb 18, 2007 | 11:24 PM
jshdrk's Avatar
Default Rincon leaking coolant
My 03 Rincon is leaking coolant from a small hose that is connected on the bottom of the thermostat housing. I cannot find where it goes to I havent noticed this problem before and i dont know if something else might be wrong if anyone has had this problem please help.
Old Feb 18, 2007 | 11:51 PM
ForemanDan's Avatar
It sounds like you are talking about the water pump, not the thermostat. The thermostat is on top of the engine. There is a weep hose on the water pump. Is the little hose straight or does it have a bend in it? The 03 models had problems with the weep hose and they were replaced by the new bent style. I think they allowed dirt into the hose and messed up the seal. If this sounds like yours, you may need a new water pump. How bad is the leak?
Old Feb 21, 2007 | 11:38 AM
3ismorethan4's Avatar
it sounds like liquid cooling causes more problems than good .
exmotocrosser
Sep 13, 2019 06:12 AM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
