engine noise
Old Dec 17, 2000 | 08:35 PM
BUZZSAW's Avatar
i change my oil yesterday and after going for a short ride i noticed a ticking sound coming from the engine at an idle.rev it up,it goes away,when it returns to an idle the noise is still there.it is a 2001 ac/500 with 300 miles on it.it is still under waranty.any input would be comforting!
Old Dec 17, 2000 | 10:45 PM
KingQuad0014's Avatar
When was the last time you had your valves re-adjusted? I had to have my 300's adjusted at about 150 miles since it had broken in at the time maybe yours is just seating now.
Old Dec 17, 2000 | 11:12 PM
BUZZSAW's Avatar
re-adjusting the valves was my fist though,i had a 500ac with 1,400 miles on it,never had a wrench on it,a friend of mine has a 400ac with 900 miles on his,he had his checked but the dealer told him it was in spec's.i'm going to try to get it in the shop this week and hope that will cure the noise.
Old Dec 17, 2000 | 11:37 PM
JKB's Avatar
JKB
If the idle is set to low the decompression valve will tick quite loud, and this is normal. I have noticed it on mine when I turn the idle way down, the dealer confirmed it was normal.
Cheers Jim
Old Dec 18, 2000 | 03:28 AM
BONER's Avatar
THATS what the **** ticking is!!!!!!! Good thing, I thought it was piston slap. That would realy suck to have to bore it out and put a bigger piston in it. I wounder if I could use a Foreman Piston???? It is 3 mm larger(6.43mm with the big bore), but would it actually work????
Old Dec 18, 2000 | 09:56 AM
BUZZSAW's Avatar
went out last night and started my ac to listen to the noise again,what i heard wasn't valve noise.when i rev it up and it gets back to almost an idle it clicks,like something engaging and disengaging. once reving up and once coming down.any thoughts?
Old Dec 18, 2000 | 09:57 AM
BUZZSAW's Avatar
Old Dec 18, 2000 | 08:19 PM
BONER's Avatar
Did you read what JKB said AT ALL?? I think he answered your question.
Old Dec 19, 2000 | 09:13 PM
BUZZSAW's Avatar
took my ride in to the dealer today,he listened to the noise and he told me that because i'm using light oil for the winter(5w30)that i will hear a little clutch noise.i never noticed it before i changed my oil.i had to put in a little isoheet in the gas, having moisture problems.weather man says -5 tonight.
greg74
Sep 10, 2019 03:03 PM
ronnierhino06
Nov 9, 2015 12:56 PM
hondarider1234
Jul 21, 2015 11:53 PM
ghost civic
Jul 19, 2015 10:13 AM
D-Hagz
Jul 4, 2015 02:19 AM
