TRX70 bogging down
Old Feb 22, 2007 | 09:37 AM
ridd's Avatar
Default TRX70 bogging down
I just bought an 86 trx 70 for my daughter and it doesnt run very well. It starts and drives but if I get somewhat aggressive with the throttle, it boggs down and dies. I replaced the carb with new and still runs the same way. I replaced the plug, checked for exhaust leaks, replaced the fuel lines and still the same thing. any suggestions?
Old Feb 22, 2007 | 09:58 PM
doubled1's Avatar
some bikes have a rubber boot that connects the carb to the engine. they can get a hair line crack that you cant see. you might try taking it off and squeezing it to see a crack. also if you have a oiled air filter it might have to much oil on it. the first time i cleaned my sons crf50 air filter i put to much oil on it, and it did the same thing. i recleaned it and it worked fine.
Old Feb 22, 2007 | 10:02 PM
doubled1's Avatar
also if you get it fixed yet us know what the problem was. thanks
Old Feb 22, 2007 | 11:30 PM
Hoyt34's Avatar
yo son if you get yo daughta a yfz or a rappy she aint be boggin down, then she be fly like a straight g.
Old Feb 23, 2007 | 08:44 AM
ridd's Avatar
I had also cleaned the air filter. I dont think I put too much oil on it.
I will check the boot. Thanks, Ill post what I find.
Old Feb 23, 2007 | 08:45 AM
ridd's Avatar
Hoyt34, I have no idea what you just said.
Old Feb 25, 2007 | 06:47 PM
BooBooToo's Avatar
I have the same ATV for my son, and had the exact same problem. I got mine dialed in by the correct combination of the pilot screw and needle jet. The manual calls for the pilot to be 1 3/4 turns out and the needle in the 4th groove, but. that didn't seem quite right (I do live at 6000 ft. altitude). I can't remember what I set the pilot screw at, but I put the needle in the 3rd groove.
Old Feb 26, 2007 | 09:32 AM
ridd's Avatar
I have adjusted the pilot and jet screws several times. I know it runs better with the choke on.
Old Mar 16, 2007 | 04:22 PM
nvrenuftoys2's Avatar
Has anyone checked the gas take? Mine bogs to ? Could there be something troubling the gas tank?
Old Mar 21, 2007 | 03:32 AM
85Rrider's Avatar
Is it possible that it is points related?
On my ATC70, I ended up replacing the points - and it fixed all of the 'hard idle, dying after running, etc' problems.
also - on the 70 - there is that little filter by the petcock, make sure that guy is free and clear.
-Wayne
hueby
Nov 6, 2015 11:34 AM
handyjc1
ATC 3-Wheelers
Oct 23, 2015 07:15 PM
Sassinm1
Sep 30, 2015 04:23 AM
essonlaker
Sep 10, 2015 01:12 PM
spark1051
Utility ATVs
Sep 4, 2015 07:58 PM
