2004 Foreman 4x4 Question Wheel Hop?
Old Feb 23, 2007 | 09:52 PM
Lettereat's Avatar
Default 2004 Foreman 4x4 Question Wheel Hop?
I just purchased this 2004 Forman. When I ride it in deep snow in 4wd the front end jumps as if it's wheel hopping. It looks like it's shifting from 1 tire to the other in the front and makes it jump. Is this normal or do I have some sort of problem? Any suggestions??
My dad has a 2004 Rancher and it doesn't do this. Thanks in advance for your help.
Old Feb 24, 2007 | 08:47 AM
Lettereat's Avatar
Could this be the torque sensing front doing this? Has anyone else had this problem?
Old Feb 24, 2007 | 08:56 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
http://forums.atvconnection.com/mess...did/510958.cfm
An 04 does have the torque sensing differential, not the old style limited slip one. You don't hear of many problems with these. Have you checked/changed the oil in it lately????
Old Feb 24, 2007 | 09:14 AM
TLC's Avatar
TLC
Sounds normal, like the front end is just tossing the power from one wheel to the next as it fights through the deep snow. Does it do this on other conditions other than deep snow?
Old Feb 24, 2007 | 01:03 PM
hondabuster's Avatar
Hows the fluid level in the fron diff? Are the front tires the same diameter as the rear...and for that matter, are all 4 tires the same diameter? You may have to use a cloth or flexable tape measure, and check the circumference of each tire.
Old Feb 25, 2007 | 11:59 AM
Lettereat's Avatar
I did check the oil, it was OK. I'm going to change it today. I called the dealer, they sounded like it's normal, tires getting equal traction fighting back and forth. THe mechanic said they were designed for deep snow riding, what ever that means. I just got it so I'm not sure how it acts in mud or sand.
Old Feb 25, 2007 | 12:04 PM
TLC's Avatar
TLC
In mud and sand the power transfer between front wheel will not be so abrupt as in snow and will be unnoticeable smooth.
Old Feb 25, 2007 | 03:48 PM
LittleBill's Avatar
its normal in snow, the diff keeps changing power to the tires, you have nothing wrong as long as it only happens in snow, or certain type of mud, where your not really going fast but putting down alot of power
Old Feb 25, 2007 | 06:54 PM
Lettereat's Avatar
IS it going to hurt anything by doing this? It seems like it would be hard on the equipment? Thank you for your reply's on this.
Old Feb 25, 2007 | 07:24 PM
LittleBill's Avatar
i have never heard of a blown diff doing this, mine does it all the time in the snow and has not failed yet. does it seem bad? yea but i haven't seen any issues yet
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
heath legg
Jul 24, 2015 01:01 PM
Jul 22, 2015 05:00 AM
