how do u take off the chain
Old Mar 1, 2007 | 12:55 AM
2006ds650xrider's Avatar
Default how do u take off the chain
hey guys i feel kinda stupid asking this but how do u take off the chain to change the sproket.
i cant find a master link. im gonna go and look again but just in case how would u take it off without one?
brent
Old Mar 1, 2007 | 01:35 AM
DragonDJ11's Avatar
YOu will need to loosen the 4 carrier bolts in the rear. Put a small screw driver through the hub into a little slot in the carrier. Roll it forward or backward and it will either tighten the chain, or loosen it. At that point you can slide the chain off of the sprockets and change. Reverse order to put back on. Nope, no master link in stock chain....
Old Mar 1, 2007 | 05:46 PM
thanks man
brent
Old Mar 1, 2007 | 06:02 PM
FatHolly's Avatar
yup... get out your grinder
Old Mar 1, 2007 | 07:11 PM
alright i cant get the chain to loosen enough to just slip off the sprockets.
and after that how do i take off the sprocket. put it in gear? no?
and will i have to grinder up the case saver?
brent
Old Mar 1, 2007 | 07:55 PM
bombrider04's Avatar
No, when you loosen up the rear bolts like what was mentioned before you should turn the carrier in the rear and the chain will loosen or tighten whichever way you turn it...Loosen the chain and then I am guessing you are changing a front sprocket you will need to loosen the large nut on it and take the case saver and stuff off...I usually put the parking break on to loosen the large nut on the front sprocket...Now if you are changing out your sprocket because the front one is warn, then I would recommend changing the rear also and the chain, but if you are doing it for gearing then inspect everything and if all if good then put the procket on...Once you have the new sprocket on tighten the nut back up and make sure everything is in line and tighten the rear carrier leaving slack in your chain...once everything is tight, clean and lube your chain and you are done. any ?'s let me know.
Old Mar 1, 2007 | 07:56 PM
what they ment by the grinder is you will need to grind off one of the pins on the chain to get it loose, but you won't need to take the chain all the way off for changing out a sprocket.
Old Mar 1, 2007 | 10:02 PM
bombrider yes im changing the front sprocket for gearing and i did loosen the chain.
to loosen the nut is it normal, (leftly losey)?
and what do you mean by grinding the pin?
thanks again
Old Mar 1, 2007 | 10:05 PM
cynick's Avatar
Yes the threds are normal. You only need to grind the pins if you are going to put in a masterlink. Other than that you can do it by loosening the chain.
Old Mar 1, 2007 | 11:08 PM
well ive loosend the chain as much as i dare it probley moves bout 3inches but not enough to get it off the sprocket.
i really dont want to have to put a master link in . anybody
