Aftermarket Carb caps for Banshee
Old Dec 18, 2000 | 04:58 PM
bansheepower's Avatar
i was wondering if anyone knows where i can get new carb caps for a 2000 banshee. i want to get rid of that TORS crap. Any replies will help... thanks
Old Dec 18, 2000 | 08:37 PM
rawze's Avatar
i got my caps from tjs parts express-i buy alot from them, their # is 1 800 256 9309
web www.tjpartsxpress.com
rick
Old Dec 18, 2000 | 10:46 PM
hey thasnks for the the reply, where on the site is it i am having a bit of trouble.....how much did it cost ya......and did it get rid of the hard throttle on the banshee.......thanks
Old Dec 19, 2000 | 12:09 AM
Jennifer's Avatar
Motion pro makes a setup also to relieve you of the garbage on top of the carbs. It won't relieve the stiff throttle though. Although buying a single carb setup will.
Old Dec 19, 2000 | 12:37 AM
ridzhard's Avatar
Nac's racing at nacsracing.com can hook you up with everything you need to accomplish this mission. Be advised, you will get a drill bit and a tap to set the carbs up for the idle screws that come with the kit. Now is a perfect time to get rid of that nasty thumb throttle and throw a twister on that machine. Banshee's are a natural for the twist. If you just gotta go with the thumb, I've been told to slightly shave or grind a little on the sides of the springs (be careful or you will be ordering new ones) to decrease the spring rate. good luck.
Old Dec 19, 2000 | 07:58 PM
Thanks for all the relpies.....but is there anyway to make an easier pull, while retaining stock cabs with new caps...i have looked at nacs, but is there anywhere that is cheaper? thanks
Old Dec 19, 2000 | 10:51 PM
Rob4092's Avatar
I have Kiehen 35mm Air Strykers and had a similar problem. To solve it I did two things:
First, I removed the small return spring located in the handlebar throttle housing where the throttle cable attaches to the thumb lever.
Second, I removed the springs from both carb slides and took them down to my local Ace Hardware Store. I was able to find the same diameter spring that was about 1/3 shorter. I then installed them in place of the original springs.
This eliminated the hard pull at a cost of less than $4.00!
Good luck!
Old Dec 20, 2000 | 12:13 AM
itsshemp's Avatar
Toomey Racing sells Carb caps. They should be able to help you out. I think they run about $6-8.
Old Dec 20, 2000 | 09:41 AM
sAyIt_fmf's Avatar
The motion pro kit is around $55
Old Dec 20, 2000 | 04:10 PM
Again thanks for all the replies... i am going to get new caps from somewhere. not sure where yet....so just removed the entire spring from the throttle housing......well i will do something..thanks again
Dirtbikemike1
Jul 11, 2015 03:36 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
Jul 7, 2015 11:00 PM
