Rad hose Tee for Temp gauge sender?
Old Mar 4, 2007 | 01:01 PM
lhamagedon's Avatar
Default Rad hose Tee for Temp gauge sender?
I finally found one on eBay for $25 it's made from billet aluminum and fits the Ds650's 3/4" or 19mm radiator hose.
Let me know what you think?
or If you know of something better?
Do an eBay search for " Radiator Hose Tee Fitting for ATV temperature gauge "
Item # 330095017127
Thanks.
Old Mar 24, 2007 | 03:52 PM
lhamagedon's Avatar
I finished up the install of the gauges and Tee.
I also managed to fit the Tach, Oil PSI,water temp, and ignition all on the dash.
I posted some pic's on my photo page.
Old Mar 24, 2007 | 06:26 PM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
That is a very clean set up you have there And dude the trak setup is out of this world i like it very much....[img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 24, 2007 | 06:30 PM
lhamagedon's Avatar
Thanks.
It not only looks cool but it really goes through the snow as well.
I take it Ice fishing all the time.
Old Mar 25, 2007 | 12:30 AM
FatHolly's Avatar
Tracks = [img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 25, 2007 | 12:42 AM
MRDS650's Avatar
Canadian and Proud of it !!!
How do the tracks work - Can you cruise threw fairly deep snow as well ? Did you make the skies yourself ? Where did you get the track kit and how much did it cost ?
Sorry for all the questions, but i was thinking of doing the same next year. There is why to much snow here in the winter to even get my bike out of the shed !!!
Old Mar 25, 2007 | 09:28 AM
lhamagedon's Avatar
Here is the link to where I purchased my Ski and track setup.
www.atvtrack.com/en/faqT.html
I'm just headed ice fishing so I will check in later.
Old Mar 27, 2007 | 09:20 PM
lhamagedon's Avatar
Hi MRDS650
Sorry I took so long to get back to you I've been out of town.
The Track kit is very easy to install you just use the existing tire lug nuts and one cotter pin per track or ski.
It takes about as long as changing your tire 15 to 20 min max.
I think the kit cost about $2500. Canadian shipped. (A sled may be cheaper)
It will go through three feet of snow no problem, but when you get into four feet or more you will get stuck,
but only if you stop. So keep it pinned in the deep stuff.
The Track height is the equivalent to a 26" tire so it takes its toll on your top speed.
It will knock you back 20 mph, so 50mph tops.
I changed my front sprocket to a 14 tooth and it made a big difference.
Old Mar 28, 2007 | 12:22 AM
MRDS650's Avatar
Thanks for the info
Your right a sled may be cheaper !!!
Old Nov 26, 2007 | 08:58 AM
lhamagedon's Avatar
In case your still interested I have the track and ski kit for the DS650 listed on eBay. The reserve is set to less than half of a new set.
shimanok2
Jan 29, 2016 07:37 PM
Sassinm1
Sep 30, 2015 04:23 AM
panicmanic
Sep 28, 2015 12:59 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Halffast17
Sep 11, 2015 02:30 PM
